Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - master cylinder interchange
Old 01-12-2008, 12:50 AM
Triaged Triaged is offline
The bigger (1-1/8" vs 15/16" for the S10) master cylinder won't make the brakes drag. It will make your pedal harder to push and firmer. However my guess is that you either have a bad master cylinder or still too much air in the lines.
