Master Cylinder Leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2004, 02:28 PM
70SPORT's Avatar
I have '70 pontiac lemans i just replaced the master cylinder bleed the whole system filled it to the proper level and it leaks out at the top throught the cap.........Im completely lost I even took some fluid out of the resevoir and its still leaking out the top.......Im almost sure its the top where the cap seals to the unit its self im stumped dont know if i have a bad master or what any help would be appreciated.....................thanks
Old 05-25-2004, 02:51 PM
poncho62's Avatar
Wiki Edits: 5
Replace the rubber seal in the top.
