Master cylinder lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2006, 06:34 PM
I need to make sure I have hooked up my lines correct, how do you tell which line goes to the rear and which goes to the front? I have the large line going to the rear and the small going to the front, is this correct? Should I still use residual valves? I have disc front drum rear.
Old 10-01-2006, 06:53 PM
Wiki Edits: 31
the lines for the front go on the port closest to the firewall, rear, to the port closest to you looking from the front. residual valve in rear drum line if the M/C dosn't have it intergrated
Old 10-01-2006, 09:43 PM
Exactly.
Another way to tell is that most disc/drum master cylinders have a larger reservoir for the disc brakes.
Master Cylinder Lines 68NovaSS Suspension - Brakes - Steering 10 03-29-2006 08:54 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
