Master cylinder location HELP!!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-18-2009, 07:34 PM
Last journal entry: comming along
Ok. I'll use the 1/4" steel plate..
  #17 (permalink)
Old 09-19-2009, 12:52 PM
Talked with a neighbor that has a 40 Ford Coupe.. He said after looking at the location and all that what I have will be fine.. If it were a bigger area to cover.. Then I would have to go with 1/4", but with the 5x8" area.. It breaks down to 4x5". He said the frame I have isn't any more than 1/8".
Got the booster in. Have to do a little cutting to ge the master in, but nothing important. Then I ran into another problem. I think I have the answer, but thought I should ask first. From the pictures I added.. You can see that the arm for the brake peddle hits the steering column. What I was thinking is to cut the arm down about 2-2 1/2" where it bends. Then both bolt and weld it back on farther down on the arm. It would both clear the column, and make the peddle closer to the floor.. Sound ok??
ID:	40791   Click image for larger version
ID:	40792   Click image for larger version
ID:	40793   Click image for larger version
  #18 (permalink)
Old 09-19-2009, 08:26 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
If you are speaking of shortening the arm that is between the pivot point and the bend where it turns up to meet the floor pedal, then that will change the pedal ratio in such a way that more foot pressure will be required on the pedal to achieve the same braking force. Perhaps the following will help.
http://www.jalopyjournal.com/forum/s...d.php?t=114771
  #19 (permalink)
Old 09-20-2009, 06:16 AM
Thanks.. Not all that good in math though.. So even looking at this.. If I put a bend down a couple of inches up from the pivot to the right and then straighten it up.. Only other thing would be to find another bolt on booster mount (CHEAP) and cut all that crap out and move it again.., or get longer bolts and put 3/8" aluminum spacers on the booster mounting area, and push the master back some.. It is hard trying to figure it out when you are the only one doing it.. Lots of advice, but which one is right..
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 09:06 PM
Master Cylinder Help Needed glg97 Suspension - Brakes - Steering 2 11-06-2005 07:20 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
