Master cylinder location HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2009, 05:42 PM
Last journal entry: comming along
I bought a new master cylinder/7" power booster. The old one was bad, and undersized on my 37 Ford Tudor. I took out the old one to find out that the Ford Courier unit that was in it was a 6". I had to cut out the mounting plate that was there. I have the brake peddle assembly with the arm, and the mounting plate.It came from Speedway Motors. It is a bolt on. My problem is.. The frame work on the car was setup for that Courier. I know that it won't fit in the same sopt where the 6" was. The big questionis where are the mounted?? I have nothing under there that shows where it should go.. I think I will cut out a big section of the floor so that it will be easier to work. The body is on the frame, and the engine is in.. Thanks.. Al
Old 09-16-2009, 07:48 PM
New Member
Itís summertime*********
Last edited by cboy; 09-17-2009 at 07:17 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 09-16-2009, 07:52 PM
HUH??
302 Z28's Avatar
What? Banned the sucker.
Vince
Old 09-16-2009, 08:01 PM
a,,,,,,,,,,any idea what he is talking about??
Old 09-17-2009, 02:05 PM
Still have the problem. I will cut a section out of the floor so it might be easier to do the job.. Al
Old 09-17-2009, 02:21 PM
You probably are going to have build a new mount and posistion it wherever it fits best. The master cyl and booster, in my bucket are under the seat. It's what works best in your car.
Old 09-17-2009, 02:23 PM
but I don't think I would be cutting the floor out
Old 09-17-2009, 02:41 PM
Can see it better now, and I tink I can do it all from under the car. I just cut a piece of 1/8" steel.. I have to measure it all out, and drill the holes. Just hope the 1/8" is thick enough to hold the booster and master.. Do you know of some place where I might find a cover that has tubes on it so that I can still use the remote?? Then I wouldn't care where the master sits..
Old 09-17-2009, 06:30 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
The bracket that holds my master cylinder to the frame is 1/4" steel, welded to the frame, with gussets welded in to provide additional strength. I work with 1/8" steel on projects here and there and I would not consider it enough to hold the master in a panic stop without some flexing. Just my $.02.
Old 09-17-2009, 06:48 PM
I think I have that covered. The 1/8" plate is bolted to 1" square tubbing that is welded to the frame on two sides. On the other side, or frame side. I put extensions on the bolts. They pass threw the brake peddle bracket. You can stand on that area, and it doesn't move. There is also a spot in the back of the master cylinder. I havve a small "U"- bolt that passes threw some frame work, and slips right into that notch. (without touching the master) For just in case. Still working on it though..
Old 09-18-2009, 02:07 PM
techinspector1's Avatar
Wiki Edits: 326
It's the chongqingians spamming the board. Disregard it.
Old 09-18-2009, 02:16 PM
Wiki Edits: 326
I got curious about this, so went and sat on the floor with a bathroom scale against the wall. I was able to push 170 lbs pretty easily. If you multiply that by a nominal 4:1 pedal ratio in a power brake system, the bracketry will see a 680 lb force applied.
Old 09-18-2009, 06:56 PM
I looked at it again, and junked the 1/8" for 1/4". Like was on there before. I have to cut it all out, but I can use the other as a pattern. I also have some 1/4" aluminum plate.. Which would be better??
Old 09-18-2009, 07:08 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
1/4" steel would be the best.
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 09:06 PM
Master Cylinder Help Needed glg97 Suspension - Brakes - Steering 2 11-06-2005 07:20 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
