Master CYlinder manual or power - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 10:38 AM
I did search this.
I have a T-bucket. The master cylinder is leaking. The one in there is a Raybestos 39174, 1980 Fairmont, specs say manual brakes. The specs for the power and manual replacement seem to be the same, 7/8" bore same outlets. The cost difference is the power brake m/c is about $30-$40 and the manual $100-$150.
How can there be such a difference?
Can the power be used?
Thanks,
Bill
Old 03-19-2012, 03:43 PM
35terraplane's Avatar
Master cylinder
Originally Posted by longt
I did search this.
Thanks,
Bill
You don't need a power M/C on a "T" bucket, why don't you just rebuild the one you have?
Bob
Manual Master Cylinder failing or prop valve? tubbedz Suspension - Brakes - Steering 1 12-28-2009 03:10 AM
'55 Chevy Power Disc Master Cylinder Frankentruck Suspension - Brakes - Steering 1 10-26-2007 08:47 PM
Power master cylinder swap 30 sportcoupe Suspension - Brakes - Steering 3 05-02-2006 08:42 PM
Chevy master cylinder power or manual Eric64 Suspension - Brakes - Steering 7 05-26-2005 05:43 PM
Power brake master cylinder without booster? BillyJoe Suspension - Brakes - Steering 7 02-12-2004 02:00 PM
