Which master cylinder for me? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2009, 07:41 PM
I need some help with my 65 chevelle....I bought the car with a disk front/drum rear brake kit already installed, and it has a manual master cylinder. As I was finishing the engine bay this summer, I went and bled all the brakes all front and rear. The master cly. started leaking at the firewall where the booster bolts up. Is it worth trying to fix with a new seal, or should I just buy a new master? I just dont know what master to buy for manual disk brakes. I was looking at a Dorman M89160. Would this be the right fit? Thanks for any help.
Old 09-20-2009, 07:56 PM
302 Z28's Avatar
Is it a GM master cylinder or an after market type? I would go back with a new GM master cylinder they can be had in power or manual and if you use one for a later 70ish Chevelle or 70ish Camaro you can even get one for front disc and rear drum.
Vince
Old 09-21-2009, 09:27 AM
I dont know if it is a GM or aftermarket (probably another reason its leaking) Any idea where the best place is to go for one? SSBC, or Classic performance Parts have a good selection, but the Dorman I mentioned above seemed to have the correct bolt location...you think it will work? Maybe I can contact Dorman directly.
Old 09-21-2009, 12:30 PM
302 Z28's Avatar
I would just go to your local auto parts store and ask for a NEW Raybestos or Bendix master cylinder. DO NOT accept a house brand. Take a look at 60's Corvette or 60's Chevelle or Camaro. There is no need to pay big money for a master cylinder from those places online. A new master cylinder should cost no more than about $60 at your local parts store. DO NOT BUY A REMANUFACTURED ONE EITHER.
Vince
Old 09-22-2009, 01:55 AM
I will ask the nearest NAPA....I will let ya know what I find. Thanks.
Old 09-22-2009, 05:10 AM
78 camaro manual brake master will do it for ya.Cheap and available.
Old 09-22-2009, 12:04 PM
Thanks guys....as always, your knowledge saves me money!!! The only way I will finish this project.
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 09:06 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
