Master Cylinder Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2007, 10:39 PM
crusherdbuzz's Avatar
71 Chevrolet Nova
I recently upgraded my 71 nova to power discs in the front. At the time I didn't paint the new master before installation and it is now in the car. Any type of paint I can put on it that will protect it from rusting? There is already a light coat of rust on the master, but that can be removed easily enough with just a small wire brush. I was thinking about painting some sort of rustolium primer on the master and follow up with some rustolium paint. I'm not sure if that will hold up anymore to brake fluid though.
Old 01-28-2007, 01:40 AM
Bare Knuckles Champ
Last journal entry: Made a wrench...
Eastwood has a whole line of various underhood finishes & their site will show you what each looks like on the item. I was a little skeptical on their stuff until I 1) put my hands on all the different finishes at SEMA, 2) started using their stuff regularly.
I'd recommend either their Aluma Blast or Detail Grey, depending upon the look you want. Both can be found here:
http://www.eastwoodco.com/jump.jsp?i...90&iSubCat=396
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
Need help adapting brake line to master cylinder RodFather Suspension - Brakes - Steering 4 01-04-2005 02:41 PM
master cylinder leaking. hiball Suspension - Brakes - Steering 4 12-30-2004 06:40 PM
4 wheel disc master cylinder qckshftn56 Suspension - Brakes - Steering 2 05-23-2004 10:30 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
