-   -   master cylinder plumbing (http://www.hotrodders.com/forum/master-cylinder-plumbing-168007.html)
maninacoupe 11-06-2009 08:51 PM
Guys
Help me out. This may look like a stupid question but, here goes. How do you distinguish which port is which on a master cylinder ( front and rear)? I got a #mc39027 master cylinder (1976 to 1980 Chevy Monza m/c) to go under my 34 Ford. I need to go to a 7/8 bore master cylinder to achieve better braking. And I don't want to plumb it wrong. :confused:
alittle1 11-06-2009 09:13 PM
First port from mounting bolt goes to front cylinder, second port goes to rear cylinders, generally.
66GMC 11-06-2009 09:15 PM
Please diregard my previous post.
I was generalizing, and this is too important of an issue for that.
maninacoupe 11-07-2009 09:09 AM
thanks guys, in further looking I found out. Large reservoir side goes to the front. Feel like I should have known this but,didn't. Thanks again
302 Z28 11-07-2009 09:50 AM
The larger of the two master cylinders reservoirs always goes to disk brakes which are usually on the front of the vehicle. Disk brake calipers require a greater quantity of fluid than drum brake cylinders.
Vince
