Hotrodders Bulletin Board
#1
master cylinder plumbing
Guys
Help me out. This may look like a stupid question but, here goes. How do you distinguish which port is which on a master cylinder ( front and rear)? I got a #mc39027 master cylinder (1976 to 1980 Chevy Monza m/c) to go under my 34 Ford. I need to go to a 7/8 bore master cylinder to achieve better braking. And I don't want to plumb it wrong. |
#2
First port from mounting bolt goes to front cylinder, second port goes to rear cylinders, generally.
#3
Please diregard my previous post.
I was generalizing, and this is too important of an issue for that. Last edited by 66GMC : 11-06-2009 at 09:10 PM. Reason: Generalizing. |
#5
The larger of the two master cylinders reservoirs always goes to disk brakes which are usually on the front of the vehicle. Disk brake calipers require a greater quantity of fluid than drum brake cylinders.
Vince
Here's to you DoC, you will always be here. My project 34 http://www.hotrodders.com/forum/34-...ght=34+progress |
Back to top |
Similar Threads for: "master cylinder plumbing"
| Master cylinder without booster? | Rons1stRod | Suspension - Brakes - Steering | 16 | 11-05-2007 09:06 PM |
| 39 Deluxe master cylinder adapter? | MM in NM | Suspension - Brakes - Steering | 4 | 09-30-2005 03:42 PM |
| Single to Dual Master Cylinder | swazo | Suspension - Brakes - Steering | 2 | 10-19-2004 08:00 AM |
| Confusing master cylinder ports... | Externet | Suspension - Brakes - Steering | 2 | 12-08-2003 08:18 PM |
| Stang master cylinder | Old Crow | Suspension - Brakes - Steering | 3 | 06-10-2002 12:40 PM |
