Master Cylinder Problem need help!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 07:00 PM
Last journal entry: Rear End Disassembly
I am having trouble with my master cylinder on an 81 honda bike and are not sure if I'm just doing something wrong or what. Problem is im leaving on a trip in 2 days and I need this functioning.
I replaced all 3 front brake lines on the bike and added fluid to the resevoir. It didnt go down at all so I took off the line directly to it and nothing was coming out. I then applied the lever and still nothing came out. So in needing to bleed the brakes I am not getting any fluid to come out of the cylinder to the lines.
However, I took off the line off of a similar bike i have and it started doing the same thing. So that made me wonder if I was just doing something wrong. Kind of odd because I've bled the brakes many times on cars and never had this type of problem..
Old 05-23-2005, 07:12 PM
30desoto's Avatar
Dodge ain't all bad
71gtx
When I owned a 78 honda I replace the master cylinder on it, it took forever to get the air out of the lines, thought I was going to wear myself out doing it. If you don't have anything to pump the lines free of air with brake fluid, then just keep pumping and it will start, system works the same as a car but does not have the pressure out of the master cylinder.
30dee
Old 05-23-2005, 11:22 PM
camaroman7d's Avatar
Bikes do take a while to bleed by pumping. If you can swing it go pick up a hand bleeder (vacuum pump) it will make your life much easier.
Royce
Jeep...6 cylinder swap problem. poncho62 Engine 1 04-09-2005 05:29 AM
Need help adapting brake line to master cylinder RodFather Suspension - Brakes - Steering 4 01-04-2005 02:41 PM
Master Cylinder Leaking 70SPORT Suspension - Brakes - Steering 1 05-25-2004 02:51 PM
Master Cylinder losing fluid jboy Suspension - Brakes - Steering 6 05-05-2004 06:01 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
