Master Cylinder Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 08:35 AM
72NOVA454
I have a new master cylinder for a disc/drum brake application. One of the reservoirs is larger than the other. Which is for the front disc and which is for the rear drum?
with the master installed in the car, the larger reservoir points toward the front of the car.
thanks.
Lee
Old 03-22-2010, 08:50 AM
302 Z28's Avatar
The larger reservoir is for the front disc brakes, they require much more fluid than drum brakes.
Vince
Old 03-22-2010, 08:52 AM
38mike's Avatar
big/little reservoirs?
Lee:
The larger reservoir is for the front discs. Just a few days ago (maybe a week ago or so??), we had a thread going on here about routing brake lines, etc. Search for it and you might find it useful with some related questions.
good luck.
Master cylinder problem? oldred Suspension - Brakes - Steering 8 05-26-2009 12:58 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
54 dodge master cylinder modification Magnus_Jager Suspension - Brakes - Steering 2 01-04-2006 08:38 AM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
master cylinder differences 56don Suspension - Brakes - Steering 2 12-30-2002 08:23 PM
