Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Master Cylinder Question!!!
Old 11-05-2002, 04:12 PM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
If you look at the system, they have it set up so that it is impossible to connect it wrong. It only fits together one way and was set up that way so as to avoid missassembly wrong at the factory and so they would not be sued. Just make sure that you have the big volume side of the master cylinder feeding your front disc brakes. If you use the factory distribution block, you won't need a proportioning valve, but if you are mixing foreign components, yo may need one.
