Master Cylinder questions now - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2008, 07:07 AM
Ok, I got my brakepedal assembly straightened out, 180 degree under dash. But now I need to find a factory style master cylinder that has disc/drum, a 1" bore, and roughly a 1.5" stroke length. If anyone has any ideas, hit me up with them. Thanks.
Old 12-25-2008, 10:13 PM
just head to napa and ask to see the book. They have a book that has all their master cylinders complete with illustrations, bore, and stroke and line out application. That's the easiest way to go.
Old 12-25-2008, 10:32 PM
406 bug's Avatar
9.82 @ 139mph
Wilwood has one they call the chysler style. It uses OEM parts. They sell for about 100 bucks. Speedway motors and others handle this one. I have one in use and it works very well. Has a bore of just over one inch and travel of about 1 3/8 if I remember correctly.
Old 12-26-2008, 06:36 PM
Cape Cod Bob's Avatar
http://www.mpbrakes.com/
79 Camaro master cylinder leaking Scottrn Suspension - Brakes - Steering 3 09-20-2007 06:33 AM
Master Cylinder Help Needed glg97 Suspension - Brakes - Steering 2 11-06-2005 07:20 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
