Master Cylinder Reservoir
Should the brakes from the larger reservoir go to the rear brakes ? I have disc in front and drum on the rear.
No the large reservoir is for the front disc brakes because as the brakes wear the caliper pistons extend and the extra fluid in the reservoir is so the master cylinder doesn't go dry as fluid is needed to take up the space inside the calipers behind the pistons . I never add fluid to the large reservoir unless I have lost fluid due to a leak or rebuilding calipers . If you do add fluid , the next time you replace pads and push the caliper pistons back in you will overflow the reservoir into the engine compartment . Messy , but non-synthetic brakefluid is water soluble and will wash off with a garden hose . Brake fluid also makes an expensive way to get oil stains off of your driveway . Work it in with a broom and then hose it off .
Usually the smaller reservoir is for the Front Brakes. However, with an under floor mount, with a remote fill master, the outlet that feeds the front brakes is closest to the booster.
Don't guess. Go to the Mp Brakes web site and locate the braking system you are working with. They offer a lot of technical information as well as installation instructions for all the different brakes with pictures. Look under their Tech Support tab in the upper right and there are drawings of how to plumb different brake configurations. http://www.mpbrakes.com/index.cfm |
The larger reservoir is plumbed to the front disc brakes. The link you provided has a link that not only shows that with photos but states it about halfway down the page. here is the LINK |
I stand corrected and the point is made that it is best to check an authoritative source rather than guess.
Adantessr,
Gee, all capital letters. Does that mean you want to spank me? |
OK Guys and Gals ... on to the next problem. I have the M/C plumbed the way it should be. However, in trying to bleed the brakes, I cannot get the air out of the rear cylinders.
The M/C is under the floor board and I have a residual valve to the front disc brakes and a residual valve and a proportioning valve to the back drum brakes. The front disc bled perfectly, but the rear has been a pain in the differential. I have tried power bleeding them and bleeding them manually with no success. HELP !! |
It sounds like you have a lot of connections to the rear brakes, you might want to take a look at them to be sure they are not sucking air
Artificial Intelligence is no match for Natural Stupidity Chet |
Be sure the bleeders are still tight in their bores when they're loosened for bleeding, too. A wrap of teflon tape will prevent air from being drawn into the system from around the threads. Also be sure the pushrod for the master is clear of the piston by a small margin and isn't putting any pressure onto the piston at rest. The return spring can sometimes allow the pushrod to actually rest on the piston. If the piston is depressed at all, there will be problems w/bleeding and getting a good pedal. |
Excuse me for asking a real dumb question , but I assume you mounted the rear wheel cylinders with the bleeders on top . Not trying to be a smart alec , just don't want to miss anything . I have one or two times had trouble with trapped air from using too much pressure on the brake pedal when bleeding . It sounds like you have power brakes and I have had best results with the engine running with power brakes and steady even pressure on the brake pedal and not stroking the master cylinder all the way to the floor . And as Cobalt327 said , make sure that the return travel lets the master cylinder piston come all the way to the stop . If it is down at all , it won't let fluid get back in front of the piston.
Just to note: If you are dealing with discs on all fours, the primary port on the MC should serve the end of the vehicle which has the greatest effective piston bore; this could be front or rear. |
Thanx for the answers guys. The bleeders are on top. The lines are straight except for 1 90 degree. The fronts (disc) bled fine. I do get pedal after I bleed one side, but when I bleed the other side if I wait for a minute I lose pedal and when I go back to the first side, tons of air. I have triple checked all fittings. The problem moves from one side to the other. It seems like I'm chasing the air.
| Clutch master cylinder G-Body T5 swap | greenmoonshine | Transmission - Rearend | 4 | 05-07-2010 06:37 PM |
| gm booster with gremlin master cylinder | candrive55 | Suspension - Brakes - Steering | 6 | 02-16-2010 10:36 AM |
| Master cylinder without booster? | Rons1stRod | Suspension - Brakes - Steering | 16 | 11-05-2007 09:06 PM |
| using only the master cylinder and takin out the break booster | Arillious | Suspension - Brakes - Steering | 12 | 08-14-2007 11:02 AM |
| 39 Deluxe master cylinder adapter? | MM in NM | Suspension - Brakes - Steering | 4 | 09-30-2005 03:42 PM |
