Master Cylinder Rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2006, 11:26 AM
spanky36's Avatar
Spanky`s Fix It Shop
Master Cylinder Rod
I have a Ford Granada master cylinder I`m using on a project. The pedal rod has a little clip on it that snaps into a groove in the master cylinder. Is there anyway to get the rod out?
Old 03-18-2006, 11:48 AM
powerrodsmike's Avatar
Wiki Edits: 161
I would try a slide hammer. Watch out though, you will be stressing the snap ring that holds the piston in the M/C. You would probably save yourself alot of hassle by buying another MC that doesnt have the pushrod installed.
BE different....ACT normal.
Old 03-18-2006, 11:57 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Some are almost impossible, some pop out easily. I never reinstall them, they really are not needed in service, but were used for faster assembly time at the factory.
Manual and power cylinders are the same except for the line output port diameter.
79 Mustang ONLY manual cylinder (inches not metric) will bolt on and provide slightly easier pedal feel on manual systems.
Old 03-18-2006, 01:34 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I always throw that little clip away.....It is not really needed and then you can easily get the rod out when you want to.
Old 03-20-2006, 03:50 PM
spanky36's Avatar
I used a slap hammer and got it out. It is a new M/C and thought maybe someone out there had ran into this and might have a trick to remove it. Thought I`d ask before using the hammer on it. Thanks Spanky
383 vs 350 TheCiscoKid Engine 86 05-03-2008 04:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 10:03 PM
master cylinder leaking. hiball Suspension - Brakes - Steering 4 12-30-2004 07:40 PM
Master cylinder recommendations wheel-7 Suspension - Brakes - Steering 3 11-04-2004 03:43 PM
Master Cylinder Leaking 70SPORT Suspension - Brakes - Steering 1 05-25-2004 03:51 PM
