Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - master cylinder to use?
Old 05-21-2009, 01:36 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
What you are describing will give you a very hard pedal. You will either need to drastically change the pedal ratio or change to a smaller bore master cylinder to get acceptable braking. If going to a smaller bore cylinder, make sure you don't run out of pedal travel. Smaller bore means less volume per pedal application and 4 wheel disks require more volume than disc/drum applications.
Andy
