Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Master Cylinder Vacuum Leak???
Old 06-26-2012, 06:07 PM
boothboy boothboy is offline
If you installed you aux vacuum line into the normal booster hose location with the check valve, I might think the booster bladder was bad. That hole your referring to is probably a vent hole for the movement of the bladder.
