Master Cylinder Vacuum Leak??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2012, 05:18 PM
Background:
72 Chevelle with moreate engine mods to a 454 I just rebuilt. Also, converted rear drums to disks.
Now this one really has me baffled. Due to a lack of vacuum to the booster/brakes I installed an auxillary Summit vac pump. Per the instructions, I ran a vac line from the pump directly to the break booster. When I turned it on there was a vac leak around the master cylinder. Upon further evaluation I was surprised to find at the bottom of the master cylinder just before it bolts to the booster, a through hole which intersects a vertical hole in the master cylinder housing. If I place my fingers over the hole I eliminate the vac leak. The hole looks like it was machined at the factory.
Would anyone know the purpose of this hole and if I can block it up so I have complete vac?
Thank you in advance for any input you may add.
Thanks
Old 06-26-2012, 07:07 PM
If you installed you aux vacuum line into the normal booster hose location with the check valve, I might think the booster bladder was bad. That hole your referring to is probably a vent hole for the movement of the bladder.
Which master cylinder for me? lngliv3 Suspension - Brakes - Steering 6 09-22-2009 01:04 PM
master cylinder to use? barnym17 Suspension - Brakes - Steering 21 05-30-2009 06:57 AM
need help on master cylinder gun70runner Suspension - Brakes - Steering 2 06-22-2006 04:29 PM
Master Cylinder 46_stvblt Suspension - Brakes - Steering 3 08-24-2005 10:54 AM
master cylinder vacum leak 65Guera Suspension - Brakes - Steering 4 09-14-2004 01:21 PM
