Master cylinder without booster?
I am building a 55 Ford with a 429 engine. I have limited clearance on my firewall for a master cylinder / booster. In fact, I don't think I have room for a booster. I've spoken to other rodders who have used a dual master cylinder for disc / drum set up like I have without a booster which allows the firewall clearance for just the master cylinder. Is this ok? What are the potential problems? One guy I spoke with has a 55 Ford with a 427 with 671 blower with this brake configuration and he said that his car stops "fine" without the booster. I'd sure appreciate some help here.
Thanks!
Thanks Vince - more questions though!
so, you used a Vette master cylinder without a booster. I see some of the catalogs (like Speedway and JEGS) list master cylinders for disc/drum applications ....... I guess it's just a matter of fitting it to the firewall. I have a master cylinder and booster combo now from a Granada that is for disc/drum set up, can I just remove the booster and use that MC?
Thanks again, Ron
Non-power brake set-ups use either a master cylinder with larger bores or a brake pedal with an increased leverage point. This is so you will not have to push on the pedal as hard. Imagine trying to stop a car with power brakes with the engine off and the booster has lost it's vacuum. For starters, it may be best to go with a master cylinder for a non-power application. And maybe change the pedal pivot point to get an acceptable amount of force required to stop the car.
Also, you will want to use a master that matches your disc/disc,disc/drum, or drum/drum setup on your car. And you still may need to add an adjustable proportioning valve. Jamie |
Have you considered a hydroboost hydraulic brake booster? It's much more compact than the vacuum boosters. It runs off the power steering pump.
Thank you all
Thanks a lot for the information!
What Joe said ...
Hydroboost (Brand New) They also used these units on several GM and Ford cars and trucks ... especially on (but not limited to) diesel-powered models. |
Shane |
Hydroboost fits in a 57 ford with a sohc motor.
I'll bet it was a hydratech unit. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
I just fell in love with a 57 Ford, that doesn't make me a bad person does it?.....LOL.
Power brakes
This may be a solution,lots of pics and step by step info.(http://www.fordfalcon2000.com/restor...owerbrakes.htm)
I'm using a Mopar mc, similar to the Wilwood. I think 1 1/8" bore. It's listed either power or manual use. One thing I would advise is stay away from semi-mettalic pads with manual disc. Get the cheap organic pads , thats what came on these cars when they were new that had manual disc. They will grab better than the metalic pads.
Thanks Chiefton
I went to a couple of parts websites and found that a manual master cylinder was listed for the Granada disk / drum brake set up so bought a rebuilt one for less than $20 bucks. That way it is matched to the brake set up. I think I'm on to my next "issue", power steering! Thinking about using 89 Mustang rack and pinion. Any idea if that is mounted in front or behind the cross member? My set up needs to be behind (rear of) the cross member. Still working on that.
Thanks for the info though!
| moving the master cylinder ans brake booster | F3RR3T | Suspension - Brakes - Steering | 7 | 09-24-2007 10:26 AM |
| using only the master cylinder and takin out the break booster | Arillious | Suspension - Brakes - Steering | 12 | 08-14-2007 11:02 AM |
| Master cylinder to fit 8" dual booster | jcarter | Suspension - Brakes - Steering | 7 | 05-25-2006 01:13 AM |
| Power brake master cylinder without booster? | BillyJoe | Suspension - Brakes - Steering | 7 | 02-12-2004 01:00 PM |
