master cylinder won't beed out - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2010, 12:06 PM
I took the lines off the m/c and it won't bleed out on it's own, do I need to replace it ?
Old 10-17-2010, 12:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To bench bleed a MC, you need to use ports that have lines running up into the half-filled reservoir, then using a wooden dowel or similar, push in on the MC piston gently until no more bubbles come from the lines.
Another way that works on some if not all MC is to plug the MC ports completely, then do the same pumping procedure. The bubbles will come from the ports at the bottom of the reservoir.
Old 10-17-2010, 01:09 PM
It has been bench bled, my question is with the m/c reservoir full and brake lines removed shouldn't the m/c bleed out on it's own ?
Old 10-17-2010, 08:33 PM
US Navy- Active Duty
if all else fails, you can get a rebuild kit for about 16 bucks. i just did the same on my truck. very simple to do.
Old 10-19-2010, 06:54 PM
S10xGN's Avatar
Gotta love a turbo!
Eventually. Every one I've ever disconnected just dripped real slow...
Russ
Clutch master cylinder G-Body T5 swap greenmoonshine Transmission - Rearend 4 05-07-2010 06:37 PM
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 09:06 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
