Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Master ® torpedo heater?&..
Old 12-29-2012, 11:24 AM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
Originally Posted by cutthroatkid View Post
Hey fellas do any if you guys know about Master® heaters?I had just got done block sanding my truck&went to turn on my reddy heater when it didn't want to start I took it apart to find a mouse nest.I thought I cleaned it all out but nope..started ran grid for a sec then it started burning I cut the power off&poured a small amount of water in it..(I know need a extinguisher getting one asap) well took it all apart cleaned&dryed everything&its like it's not even plugged in.Circuit board looks good so idk.
Well I found a master® brad 135000 btu multi fuel torpedo heater on managers special for 249.00 its the only one.Sears wants 460 something&walkmart 430+ so it sounds like a steal but I've never heard of them.Any of you guys have any experience with them?I need one asap.
My shop is insulated &well ventilated I work in the first half of shop&place it in the rear then 110 will get up to 80° when it's in the 20s but getting ready to add a wood stove.Sorry so long.Thanksq
Add wood stove can get you blown up if you work on carb's an fuel tanks.
