mastr cyl. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2013, 07:17 PM
jan bogert's Avatar
LARGE TOY BOX
mastr cyl.
hi i bench bled my master cyl. the rear bled first and then the front port. so i determined that the rear port was the front brakes. is this right? because the front brakes come on first. it is a remote fill. both reserviors i'm useing are 4 oz. front disc. rear drums. or doesn't it matter? JAN.
Old 05-20-2013, 09:11 PM
life is a temporary assignment
One doesn't feed before the other,,Post a picture of it so we can say for sure,, But the bigger reservior is for the disc brake and the smaller one is for the drum brakes,,, The disc use's more fluid then the drum...But the m/c should push the same,,, adjustable proportioning valve's are used to slow down the pressure going to the back..
Old 05-21-2013, 06:05 AM
jan bogert's Avatar
LARGE TOY BOX
i mean when i pushed in on the piston to bleed the master, the rear port pushed out fluid first, then the front pushed fluid, but not as much as the back. so would the rear port be the front brakes? there were no reserviors, i mounted 2 four oz ones on the firewall for each port, it is a remote fill master.
Old 05-21-2013, 07:37 AM
I knew what you was saying... You need to post a picture of the M/C..
What did it come off of ???
The M/C should push the same on both..
Old 05-21-2013, 09:12 AM
jan bogert's Avatar
LARGE TOY BOX
don't know what it came off of this came with my '33 willys prodject.
Old 05-21-2013, 11:17 AM
Look's to be one of the newer M/C's someone took off the reservior..
Old 05-21-2013, 11:27 AM
jan bogert's Avatar
LARGE TOY BOX
'33 willys
hey guys, i plumbed the brakes, bled the brakes, end results are beatiful brakes. 1 time bleeding i'm so happy, i'm going to throw a sirlion steak on the grill for me and the miss's who was my pedal pumper. THANKS GUYS FOR THE INFO. JAN.
6 cyl to v 8 superdc62 Hotrodding Basics 4 09-13-2012 09:13 AM
4 Cyl T5 Mac88 Transmission - Rearend 2 07-03-2011 06:27 PM
5 speed, 4 cyl or V8? Mikey_mike Transmission - Rearend 3 09-04-2005 10:54 PM
Newbie help: 4 cyl vs. V-8 manofsteel Hotrodders' Lounge 2 10-29-2002 06:25 AM
Master cyl. subdude Hotrodders' Lounge 4 06-26-2002 07:17 PM
