Matching cam with vortec heads help
Hello guys, I'm a noobie, and thinking about buying some vortec heads with springs and maybe using with my cam. I know I should just buy the matching springs and be done with it but just looking to save some $ if I can get away with. Will stock vortec springs will work fine? I have a Lunati Bracket Master Hydraulic Flat Tappet, Advertised Duration 284/284, Lift .458/.458, Basic Operating RPM Range1,500-5,200,
The matching springs specs are: Spring Rate 462 lbs./in. Installed Height 1.750 in Seat Pressure at Installed Height 108 lbs. Open Height 1.250 in Open Pressure 339 lbs. I'm unsure of what stock vortec springs specs are, cain't find any. I don't know how well it will run with stock vortec springs, I'm not gonna be doing any racing, just a street 72 c-10, 360ci, let me know what yall think. Any input will be greatly appreciated, Thanks |
Thanks guys I found a few sites with Z28 springs these are the ones yall referring to? Any will work? without machining needed? I just don't wanna make a bone head mistake, still learning alot. Luckily I have a good buddy who knows alot more than me and will be assisting me with the build.
http://www.northernautoparts.com/Pro...entoryId=50942 http://sdparts.com/details/scoggin-d...-center/sd1005 http://www.alexsparts.com/products.p...-.500-MAX-LIFT Last edited by aguilar_jimmy; 03-04-2012 at 10:05 AM. |
The ones from Northern auto parts will work just fine. That's where I got mine. The springs are drop ons and go. Just make sure you have the valve guides clearanced as required on Vortec heads 062 and 906 castings.
Thanks for the help
| chevi heads Matching | Erich | Introduce Yourself | 2 | 03-20-2009 08:53 PM |
| mix matching vortec heads. | swoodard23 | Engine | 1 | 05-20-2008 03:58 AM |
| Question on matching up heads... | swingcatt | Engine | 3 | 10-27-2003 09:36 AM |
| Matching Vortec Heads???? | BillyBob1950 | Engine | 2 | 02-02-2003 11:12 AM |
| port matching heads | nosliw721 | Engine | 2 | 12-23-2002 04:46 PM |
