matching heads with block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2012, 02:35 PM
i have a 454 #3999289 & i have a set of 990 squareport heads.i notice a couple of holes on heads that i dont see on block & im jus wondering will it run hot if i block the holes.according to castings their both early model parts.pls help me!!!
Old 03-06-2012, 03:04 PM
airboat's Avatar
They did series cooled and Parallel cooled. You can drill the holes in the block and the front cylinders will run cooler with the appropriate head gasket. With series cooled (no extra holes in block) most of the coolant has to run to the rear of the engine before coming up to the head and back to the front. At least that's my understanding.
Matching cam with vortec heads help aguilar_jimmy Engine 6 03-04-2012 02:54 PM
matching heads to a 1989 5.7 trottlebody block Erich Engine 4 05-05-2009 02:54 PM
mix matching vortec heads. swoodard23 Engine 1 05-20-2008 03:58 AM
Question on matching up heads... swingcatt Engine 3 10-27-2003 09:36 AM
port matching heads nosliw721 Engine 2 12-23-2002 04:46 PM
