Matching numbers usually refers more to drivetrain parts, to ensure that they actually belong to that car. About body parts, I doubt that they kept track of what went where.....most likely they are just part numbers, so all Mustang fenders of that year for example would be the same. Unless you are really fanatical about it, I wouldn't be too concerned.
Ontario Rodders |
mustang numbers
Mustangs of those years had the vin Number stamped on the driver's side inner fender panel. There is a cutout in the Left fender so you can see the number. The Rignt side inner fender also had the same number stamped opposite but the right fender is not cut out so the number is covered by the fender lip, you can wire brush the right side area to clean off road grime then place a carbon paper face down on a white sheet of typing paper then hold it up to the number area. rub with an eraser or sometimes your thumb and you can usually get the numbers to transfer, saves removing the fender to check to see if they match. I have seen a lot of show car mustangs with no numbers showing on the left side. either crash repair or ?? . the vin number was also on the metal ID tag with other info.:date code. body code trim color ext paint.. etc. Mustang vin numbers were asigned. when the order was processed in dearborn. orders were sent to the 3 mustang plants and the build was done to match parts availability and capability. body fixtures could only build a limited number of fastbacks each day. so the vin numbers were scrambled to match parts. . Chrysler assigned their numbers when the body was built so actual build dates are easier to find. Later years the Feds required vin numbers stamped on other parts engine, trans, etc. I don't remember what year that started. ,
Numbers.??
Thanks for the replies poncho and timo. I have an idea what i am looking at now. This car therefore will not be a matching numbers car as it has a disc brake conversion front and rear and a 347 engine instead of the original 289.
This mustang has, as you have said a VIN no. stamped in the passenger side inner fender which i discovered when i removed the fender. The drivers side guard has a cut out for the vin no. but there is no number there. I am assuming it has been repaired sometime in its history as you have said. I will have to cut out a piece of the passenger side guard to reveal the vin number before it goes back together. The guys here at the transport inspection will need to see it for its registration. We have Special Interest (SI) registration here which is about half the price of full registration. You carry a log book and are allowed 52 logged trips per year. There are a lot of Chevs, Mustangs and Rods here with this type of reg. Thanks for your info. Cheers. Al. |
| I want to rebuild the numbers matching water pump 69 Camaro... | camaro freak | Engine | 5 | 06-20-2008 02:33 PM |
| matching numbers | shagginwagonvic | Hotrodding Basics | 4 | 05-27-2005 03:10 PM |
| Matching numbers | reclusej | General Rodding Tech | 0 | 09-07-2003 12:46 PM |
| Matching numbers question? | HotRodMan | Engine | 5 | 03-16-2003 07:57 PM |
| Matching Numbers Question | deleteall | Engine | 5 | 02-12-2003 06:45 PM |
