matching paint color to powdercoat color
Is it possible to get a good color match when powdercoating some parts and painting others the same color? I had some chassis parts powdercoated and then took a sample of the color, (I had the powdercoater do a 3"X6" panel with the batch of parts so it is the same color), to the auto paint store. They mixed some paint (omni MTK, Single stage urethane) I sprayed the other parts and the color does not match very well. (at least both colors are yellow) Is this a paint shop mixing error or is it just impossible to get a good match between paint and powdercoat? Are there any suppliers that make both powder and paint that will match? I'm not going to redo anything at this point but I would like to know how to avoid this problem next time. Thanks for reading this.
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 12-09-2005 at 12:02 PM. |
Thanks Vince, that is what I suspected. The paint is basic non metallic buttercup yellow. I had to put 3 full wet coats to get it to cover fully. I am glad that this is on some mix-n-match chassis parts and it shouldn't be a big issue on this car.
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
powder coat
I work in a powder coat factory a color match is a major problem because if you have the oven temp. to high or run the line to slow the color will change. we do desk an file cabinets so the drawer fronts have to match. the auto shop mixes spray cans for us but that only matches the sample we take to them.
Thanks nissan, I think that the paint shop would have gotten the match a little better if they had a color matching system just a bit more sophisticated than the TLAR system they currently use. (TLAR=That Looks About Right.) This one gets run as-is.
| "Basic of Basics" Can I use "rattle can" paint on my car? | Centerline | Body - Exterior | 33 | 07-08-2011 12:33 PM |
| "Basic of Basics" What kind of paint should I use? | Centerline | Body - Exterior | 5 | 10-21-2007 11:32 PM |
| engine paint color code | eneas kid | Engine | 3 | 02-16-2007 08:15 PM |
| what color to paint? | jum | Body - Exterior | 14 | 07-30-2006 12:29 PM |
| what color to paint my car?????????? | neil madsen | Body - Exterior | 2 | 10-21-2002 04:19 PM |
