Material recomendations from Dan? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2010, 01:49 PM
Dan, I am trying to decide on a faux leather to use. "Ultraleather like" is what I would like to have at a lesser cost. There are about 8 gajillian kinds of stuff out there so it gets confusing. I think i want a urethane and that seems to really narrow it down because I can hardly find urethanes. Naugahyde has a line called Nauga soft that they claim is as leatherlike as faux leather can get and has 1 million dubble rub rating in the Wyz. test. But it is PVC (vinyl) not uretnane. Ever used it? Ultraleather has a perfect color for me and some of the samples of other stuff I have seen do not have the right grey or even a grey at all. Should I just bite the bullet and get the ultraleather or do you have a suggestion as to an alternative? I hate to pay that price knowing I'm gonna screw a lot of it up learning to sew. I have a bunch vinyl to practice on but I will probably still screw up some good material.
Old 09-21-2010, 09:29 PM
kristkustoms's Avatar
First name...............Shawn
I'm not Dan, but I'll give some recommendations.
We are putting Naugahyde "Majestic" in a car right now, it had the perfect color for this vehicle. I am very pleased with the material, I would definitely use it again. It is a polyurethane like UltraLeather.
Other brands to look into: Luxor Soft Touch, Dove, Infiniss, Izit Leather
Also, look into some of the recycled leathers. These have a 100% recycled leather backing, but have a polyurethane "topcoat."
Old 09-22-2010, 06:58 AM
Thanks, thanks for the replies. I had been considering majestic but it is limited on grey. I can not seem to get any samples of it to check the grey they have. Can you give me any sources for buying the products you mentioned. Not being an upholstery shop I know my options are limited. I also know of Miami, Perfect Fit, Rochford, and Your Auto, any others I should check?
Old 09-22-2010, 07:39 AM
cboy's Avatar
Last journal entry: Finished
I'm not Dan either, but he did recommend and get me this fabric for my sedan delivery from Burch Fabrics Group. This line is called "Magnificent" and I see in the color chart that there are a couple of grays...although not a huge selection.
As I recall, the fabric was about half the price (or less) of Ultra Leather back when Dan ordered it. Might have changed by now. But you may want to give it a look.
This was my first shot at doing a full interior as well and I found working with this material very pleasant...although I have very little to compare it to. I'm sure between Shawn and Dan they can steer you toward some very good stuff.
Some results:
Always learning...and sharing what I've learned.
Old 09-22-2010, 07:58 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I am Dan, and Shawn is right on the money, all of those products are terrific. I used some of the recycled leather, and was impressed with it, but it's also pricey. The neat part about it is that it even smells like leather because of the backing. My supplier's rep also told me they are doing land office business with it. Infiniss Dove and original Infiniss both have at least four shades of grays, I'd check them out. Original Infiniss has a pebble finish, and Dove has more of a smoother calfskin finish.
If I were you I'd stick with the 100% polyurethane fabrics. Ultraleather used to be the only choice around for the 100% polyurethanes, but not any more. Naugahyde Majestic is very, very impressive, it's too bad they only have two grays.
Old 09-22-2010, 01:39 PM
Thanks for more answers guys. Is the Infiness stuff polyurethane or vinyl? I would like to have the smoother grain like the Dove, maybe they have a grey that would work. Where can I ask for a sample from? The Majestic is contract grade, I think Dan said that means it is heavier and more durable which sounds appealing to me as long as it still has a good leatherlike appearance. The places I can find Majestic do not seem to offer a sample card like they do the other fabrics. Where can I get a sample of it? Maybe the grey they have that is not so dark would work for me.
Old 09-22-2010, 01:45 PM
cboy I meant to tell you that your interior looks nice. Did you mess up any material getting it right?
Old 09-22-2010, 01:58 PM
Wiki Edits: 22
Originally Posted by cpg2
Thanks for more answers guys. Is the Infiness stuff polyurethane or vinyl? I would like to have the smoother grain like the Dove, maybe they have a grey that would work. Where can I ask for a sample from? The Majestic is contract grade, I think Dan said that means it is heavier and more durable which sounds appealing to me as long as it still has a good leather like appearance. The places I can find Majestic do not seem to offer a sample card like they do the other fabrics. Where can I get a sample of it? Maybe the grey they have that is not so dark would work for me.
Infiniss is 100% polyurethane. Here's a link that has pretty good color samples: CLICK HERE Look at Pewter, Smoke, Nightfall, Charcoal, and Grayson. Contract grade doesn't have to mean the fabric is thicker or heavier, only that it is very durable, is easy to clean, stands up to chemicals, oil, UV rays, etc. Majestic is made in the USA by Naugahyde, so try to get a sample from them directly.
Old 09-23-2010, 07:52 AM
cboy's Avatar
I didn't make too many huge mistakes with the fabric itself but I attribute much of that to the number of practice panels, as shown in my journal, which I did. So one way or the other, I used much more fabric than a pro would have used. I just made my mistakes on test panels.
Also, I DID make plenty of mistakes laying down the 1/4" closed cell foam on the backer boards (also shown in my journal). By the time I was done, I had made almost every panel twice. So I had more than my share of rookie mess ups.
The bottom line is, you are very wise to be calculating for ample material. Just chalk up those additional expenses as your "tuition and fees" for beginning to learn this part of the hobby.
Old 09-27-2010, 08:19 PM
I know it is not an exact science but would 12 yards of material do a 52 pickup? Covering two bucket seats, arm rest, sides of console, kick and door panels, headliner and surround the cab behind the seats and around back window.
Old 09-27-2010, 09:18 PM
Wiki Edits: 22
12 yards would do a pickup truck easily.
Old 09-28-2010, 08:43 PM
ever heard of Majilite fabric? It is not pvc or urethane. some kind of mix of nylon and some other stuff. They claim it is the highest quality available and you can get it with sew foam already on it in 1/4 or 1/8 inch.
Old 09-29-2010, 06:49 AM
Wiki Edits: 22
Majilite makes Novasuede imitation suede. Like almost all the imitation suedes, this is made from nylon. I know it's available bonded to 1/8" sew foam , but I haven't see it available bonded to 1/4" sew foam.
Old 09-29-2010, 07:24 AM
This is not suede. would it be as good or better than a urethane product?
Old 09-29-2010, 07:47 AM
Wiki Edits: 22
All of their products are made of 100% nylon. I have never used it before, but after looking at their website, they seem to think it will outlast leather, but so will the 100% polyurethane fabrics.
Favorite Quotes schnitz Off-Topic 102 12-28-2013 07:45 AM
The best V-8 ever made NXS Engine 167 10-16-2011 08:10 AM
Help with why my upholstery material is ripping while sewing Shweaty Interior 3 07-09-2009 10:03 AM
Percy xx carbon exhaust gasket material - passed my first (and second) stress tests lowROLLERchevy Engine 6 02-17-2007 09:29 PM
Material quaility?? Bluepen Interior 2 12-02-2003 05:33 PM
