Material size for tapping with a die - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2006, 11:39 AM
zipfactor's Avatar
Last journal entry: Just starting
Hey group,
I had a question. I would like to tap this rod that I have to 3/4-16" thread with a die. Is there a formula or chart for what size the original material should be to that I can tap it to 3/4-16"? I know that the end has to have a 45? chamfer, but I have not been able to find anywhere that details the original material diameter. Thanks
zip
Old 12-13-2006, 11:45 AM
Frisco's Avatar
Glad To Be Here
If you are threading a rod to 3/4-16 with a die then the rod should be 3/4 inch (.750) in diameter.
If you are tapping a hole with a 3/4-16 tap then use the chart below.
Drill Chart
Old 12-13-2006, 12:09 PM
zipfactor's Avatar
oh, i guess that was kind of a stupid question. I've never really threaded a rod before so *shrugs*. Thanks.
Ben
Old 12-13-2006, 12:10 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
How did you know I needed one of those drill charts..
Sam
Old 12-13-2006, 01:47 PM
powerrodsmike's Avatar
Wiki Edits: 161
Watch out because some of that 3/4" rod can vary alot in it's actual size. I've seen 3/4" hot rolled round be .015" over. It gets really hard to thread when it is that much over. Messes up dies also.
Cold rolled round is usually closer, but it still winds up on the big side.
I try to take a dial caliper or micrometer to the steel yard with me and pick rod that is closer to what I need.
Otherwise I wind up turning it down in the lathe.
Later,
mikey
BE different....ACT normal.
Old 12-13-2006, 01:55 PM
zipfactor's Avatar
yeah, that is always the first thing I check is the diameter of the material. Thanks for the tips.
87 Lincoln Rear Caliper Banjo Bolt Size? sonicweb Suspension - Brakes - Steering 2 08-30-2006 01:00 PM
exhaust size help SBC S-10 Engine 2 07-17-2005 12:22 PM
Bore size question 53LEDSLED Engine 5 05-12-2005 06:55 PM
Fuel line size question 52Caddy Engine 2 07-01-2004 12:54 PM
Material quaility?? Bluepen Interior 2 12-02-2003 05:33 PM
