material suggestions
The two links below will give you a lot of information on interior rebuilding:
http://www.jalopyjournal.com/forum/s...ad.php?t=38449 http://www.hotrodders.com/kb/browselinks.php?c=26 If you have two baby girls the ABS will be way to expensive. |
How about 1/8" masonite with some vinyl or cloth glued on with upholstery spray glue. A 4X8 sheet of that stuff costs less than 20.00 and can do your whole car. It will last a lifetime if it stays even semi dry. (I did my 63 econoline like that and it stayed up fine until I hauled it off to the junk yard 14 years later) The good 3M glue is like 9.00 a can at the hardware store. Swipe a set of sheets from the OL and you got it made. hahahaha (OK so you probably don't have vinyl sheets) Fabric store for vinyl. There is also some material that they put on shower walls that is a lot more waterproof. It is a fiber reinforced plastic. Find it at the home center/building material store. Hope this helps. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 03-25-2006 at 11:32 PM. Reason: I managed to catch an afterthought as it raced by my head. so I put it in. |
The masonite I refer to is also called hardboard. Look at a dry erase board and you will see some that has the contact paper covering. Made from sawdust with a resin glue. Has a semi glossy finish on one side and a surface texture that has the imprint of a woven screen on the back. Look on the back of a dresser or cheap bookcase and chances are you will see masonite. It is cheap and durable. Wonder board is usually fiber reinforced concrete that you use under ceramic tile in a shower or countertop. That is what they used to call it here in California, any way. Has no potential use in autos. hope this helps. mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 03-27-2006 at 07:04 AM. Reason: I have to edit every thing. Maybe I have OCD? |
go with the abs dont have to worry about it warping in the future. TOM
| Recent Interior posts with photos |
| The best V-8 ever made | NXS | Engine | 167 | 10-16-2011 08:10 AM |
| How much material for a 34 ford interior? | jaxhome | Interior | 8 | 11-13-2005 08:27 AM |
| Material for custom fiberglass panels | Toyman | Interior | 13 | 08-19-2005 02:00 PM |
| Material quaility?? | Bluepen | Interior | 2 | 12-02-2003 05:33 PM |
