Matte Black on Gloss Black - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2006, 10:00 AM
blacksunshine's Avatar
Bleed Blue
I'v discussed proper paint layering for stripes (graphics) on an earlier thread with some of you, talking about painting my torino black with white stripes, laying the white first, masking the stripe laying black etc...
Well, im still contemplating white on black, but I also think flat black accents on gloss black would be cool too..a little more sinister looking, not quite as "bold" as white stripes.
I figure there are a couple of ways to go about doing this. One is spray the entire car with base, mask the stripe (or whatever) then shoot clear over it leaving the stripe unglossed. I have negative thoughts about this method because i know I will need to cut and buff the clear, and I wont be able to hit the stripe...I dont want it glossy.
OR, like I've seen on TV (wrecks to riches w/ barry white) they shot the color, shot the clear, then shot a flat black over it, most likely after it was cut and buffed. Shooting direct on top of clear is possible without adhesion issues?
Thoughs?
Old 07-05-2006, 05:22 PM
Last journal entry: 99 soft tail standard I painted
Hi BSS,me again.If I were to do the matte stripes,I would paint the car black first,clear it,sand and buff.Then mask the stripes,scuff it with a red or grey scotch brite,one coat of black base,the flattned clear.Do not leave base coat open because it will not stay on long if you do.JMO.....Im sure someone will prove me wrong tho...........
Old 07-05-2006, 11:27 PM
Bleed Blue
Hello again! Thanks, I suspect your right, I wasn't sure if you could use a flattner in clear (like I said im new). Im just having difficulties on color choice, and or stipes or not. Probably my safest bet is no stripes one solid color. I could always go back and add striped later right? Im going for a very straight, clean look. Not a too flashy hey look at me muscle car look. No emblems, only trim will be around the glass.
Old 07-06-2006, 08:23 AM
Yep,you are right,you can allways go back and do more.
Old 08-11-2006, 12:24 AM
colormecrazy's Avatar
Paintshop Dog
Matt stripes
My experience with matt stripes has shown me that adding a matting agent seems to be very inconsistent. It seems that all the variables us painters deal with are compounded when matt enters the equation. The solution I found is at your nearest Dupont dealer. Hot Huges is a satin urethane that works very well, and can be sprayed on fairly thin to minimize stripe edges. But, for now, if I was you, I'd concentrate on getting straight, black and slick first.
Old 08-11-2006, 08:34 AM
Once you choose the flattened product that will be applied do some testing to verify it is what you want. Spraying with fast dry reducers will give you less gloss, adding more flattener will give you less gloss, more flash time between coats will give you less gloss. Adding just a hint of blue tint or some graphite tint to the mix would also help set them off just a little... Bob
Old 08-11-2006, 09:14 AM
Bleed Blue
A graphite tint or even a very small hint of blue would look great. Now im thinking of no stripes, or if I do choose a stripe it will be a stock looking GT lower stripe in silver. Man...so many descisions!
Old 08-11-2006, 09:35 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Your car, your choice. My opinion - flat black stripes or flat charcoal on shinny black. Subtle, unique, similar to ghost flames.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 08-11-2006, 10:34 PM
Paintshop Dog
Matte on Gloss
If we could only dream up some way to flow between matte and gloss with out an edge line... Then we could probably get rich! I'm a firm believer that it's not finished artwork until you can't feel it. As for as the ghost reference, I love ghosting in graphics. There is a popular confusion about ghost and pearl though. A black car with flames laid out and dusted with pearl ("pearl flames")does not constitute ghost flames. On the other hand if you tear down the flames and spray it with transparent black, now you have "ghost flames". I like to think of it as art that you have to pay attention to see. I like to make folks look twice.
Old 08-12-2006, 05:27 AM
milo's Avatar
point on positive
I want to think you could use Flex-N=Flat clear and then tape off the stripes and buff cause you can shine up the Flex-N-Flat when it's buffed and then pull the mask ..
Use regular clear on panels with no stripes of course and blend with the buffer after by sanding everything with 2000 etc..
it could be done... I'm tempted to tape something out and try..
or get it painted and buffed,,, and tape everything off for stripes and use Sems Trim Black , yes it will stick and stay on the buffed clear and last 5 -10 years .http://www.perfectfit.com/product.as...15979&l2=15342
Heres a pic of some of the cleared black. I would have used the Trim Black if not for needing it to hold up against gas spills being a tank...
ID:	14072   Click image for larger version
Old 10-29-2009, 01:20 PM
ghormss1969's Avatar
Are you speaking of just putting a transparent coat over the existing gloss black? If not, it got me thinking, why not just spray a clear coat matte finish over the already existing gloss black paint. I'm painting my 65 mustang with a charcoal metallic and am thinking about doing a 'ghost' stripe approach. Can this be done with a matte clear?
Old 10-29-2009, 03:47 PM
Paintshop Dog
Sure. You can use a matt clear over it. Just realize you'll have a slight edge where the colors change.
....Howdy folks!!! It's been a long time!
Old 11-02-2009, 10:15 AM
I'm looking for some thoughts here. What I want to do is this, on a hood I have some airbrushing I want to be gloss the rest of the snowmobile I want to be flat ( it also has airbrushing on it but that can be flat). Using two guns, can I spray gloss clear over the center graphics and use the second gun with a flattening agent mixed in to clear the rest just fogging the two areas together?
Anyone tried this. I have no booth so if I sand and buff will the flattened parts get shinney?
Old 11-02-2009, 03:42 PM
Paintshop Dog
I have not tried this. But, in theory and on paper, I can't come up with why it wouldn't work. As long as the same clear, hardener, and reducer is used in both. Make certain you harden the flat clear properly. And I'd really try to keep the faded area as small as possible (quick transition in your fade). I'm thinking I'd spray the gloss clear last. Not, sure why... I guess I'd rather have a little gloss over-spray on top of the flat clear, rather than flat fogged over my gloss. As for buffing the flat, I strongly advise against that. Yes, it will shine-up. And no (from my experience) it don't loose it's gloss quite like you'd hope. I suggest you take a little extra time to clean and contain your spray area as much as possible. Nice thing about flat is that the light don't bounce off of it so much. Therefore, its really harder to see the trash in it. Not to say that you can't see it, but, you get what you get. You could (and should IMO) color-sand and buff the gloss part. Airbrush work always looks so sweet under really slick clear. Its like putting the art work under glass. OH....But, don't burn through the clear and mess up the paint under it! And, I suppose you'll really need to pay attention to the transition area. I seem... you could make the gloss area larger by buffing over the flat.
Like I said I haven't tried this. But, there's my thoughts.
Good Luck!
Old 11-02-2009, 06:03 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
If you consider the past,most all flat stripes or graphichs were decals if memory serves me right. There were a few flat graphics but most were stuck/painted on later.
Find out what Dodge does to the Black SRT Challenger Gloss Black but a flat stripe out on the hood.
Something to consider is.
Clear the whole deal,cut and buff.
Then,
Mask off the gloss edge and go back over the "flat" area with 2-3000,Abralon or Trizact pads to dull it down.This will still leave a smooth top surface but relatively flat in finish.Not true flat,but close.
Suede and gloss black on a '32 sedan McDeuce Body - Exterior 2 11-10-2004 05:21 PM
flat black hood on a gloss black car Dubz Body - Exterior 23 07-14-2004 09:01 PM
verbal description of raven black as compared to black Dubz Body - Exterior 5 02-24-2004 01:01 PM
Black is black? dh79 Body - Exterior 5 02-07-2004 05:38 AM
PPG low gloss black JohnnyJ Body - Exterior 0 09-25-2002 02:27 AM
