matte black satin black same? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2010, 07:17 PM
is satin black the same as matte black?...which is easier to spray?..someone told me that he sprayed his own car using rust oleum satin black..and gave him excellent results jus wanted to get some feedbak..thanx
Old 02-03-2010, 07:42 PM
Rag top bird's Avatar
Hot rods are still the king
Best I can tell the satin has a little more shine and the matte has a gray tint to it I would say one would be as easy to spray as the other
Old 02-03-2010, 09:36 PM
Official Solventologist
They way it was explained to me by a paint chemist was that Flat was the lowest, then Matte gloss was little higher, then Satin was next highest, then Semi-Gloss, the something called reduced sheen, then the highest or full gloss.
I wouldn't recommend the rust oleum if you plan to keep the vehicle. It might look good up front but will chalk and look pretty ugly relatively quickly. I learned my lesson on low gloss enamels....never again on the exterior parts. It ain't worth the lower cost.
If you are going to go through the trouble of painting something you plan to keep invest a little more and buy a urethane. It will hold up better and you'll be more pleased in the long run. These guys make a nice one I have used and it is affordable. They made a special color for me and it worked well. It seems like they said they could do any gloss range for me also.
http://stores.ebay.com/TheCoatingSto...subZ1553732015
The best approach is to use a pre-flattened urethane clear over a urethane basecoat but a single stage urethane flat works fine for me.
good luck!
Matte Black on Gloss Black blacksunshine Body - Exterior 15 11-02-2009 09:16 PM
Whats a good satin black paint? WickedSS Body - Exterior 6 04-04-2009 09:42 AM
satin black paint care? runn141 Body - Exterior 4 02-08-2008 12:08 PM
buffing satin black runn141 Body - Exterior 2 12-09-2006 09:02 AM
