-   -   Mattson ATom-Miser HVLP Paint gun, anybody used it? or know of it? (http://www.hotrodders.com/forum/mattson-atom-miser-hvlp-paint-gun-anybody-used-know-73567.html)
myfamiliacc 11-06-2005 06:20 PM
Doing a net search didn't find too much...
http://www.autopaintersupply.com/Merchant2...egory_Code=BLOW
http://www.autopaintersupply.com/Mer...vitysystem.jpg
So I was woundering if any of you guys might have used one....or have more info on them?
thanks
kenseth17 11-06-2005 06:56 PM
If I remember correctly at an old job of mine we used a mattson brand gun. but this was back in early 90's. It was a pressure feed hvlp with the cup on the bottom. I would rate it a decent gun as far as spraying paint, but we did to spray at a pretty high pressure when we were spraying with it. It looked nothing like that one. Plus they have probably made big improvements in hvlp guns since then. Sorry I can't help you more. For some reason I thought Mattson went out of business. Hopefully someone has used this gun and can tell you more, but for a little bit more you can get a sata or iwata which are popular guns and many people on here seem to like a lot.
BarryK 11-06-2005 07:14 PM
I had the regular gun and than the belt system gun.
They had the same tip as the chrome gun witch is the newest and mine were black.
The belt gun was about $2500 if I remember right and this must have been ten years ago.
The regular gun was about $400+ back than.
These guns at the time were way ahead of other hvlp as far as spraying.
The nice part about the gun is the head (whole unit) was easy to pop off the gun and clear or change size. The gun at that time came with a base tip and a clear tip.
Have not seen one of these in years. Sold mine to the Cadillac dealer in Augusta, shortly after I bought them. Don't remember why I did that??
baddbob 11-06-2005 07:21 PM
I had a sphon feed model that used a pressurized cup. Had the black and gold caps. Cleaning this thing was a PITA so it hung in the cabinet most of the time. It did spray nice though! I sold it on ebay for less than half what I paid for it.
myfamiliacc 11-06-2005 07:35 PM
Yes, I thought there nozzle cartridge idea was neat.......reason I'm asking is because I have a friend that works at a pawn shop, and they recently received 2 unused sets of these guns......there asking price is $150 each. Even though that is half the retail price online, I'm sure my friend can hook me up with a lower price. ;)
but
are they any good?
by the way, I believe the tip setups that come with the guns are .8 and 1.0 .......that's pretty small, but then again were talking about presser feed....who knows?
myfamiliacc 11-06-2005 07:43 PM
so the only neg. you had was the cleaning?
what tip size(s) did you have?
baddbob 11-06-2005 08:06 PM
I really don't remember what tip sizes I had but if I were to guess I think 1.3 or 1.4. Definately not .8 or 1.0. It's been about ten years since I used that gun but I'm sure the tip wasn't that small. Bob
kenseth17 11-06-2005 08:46 PM
The tip size for a pressure feed is typically smaller then for gravity or siphon. I had a tip comparison size link somewhere, but don't know where it is offhand. I have a pressure feed accuspray, and the tip is smaller then 1.3. I don't know what the exact size is, would have to look. I use it only for base though.
chadsbodyshop49119 11-06-2005 09:08 PM
OK I've sprayed with both style mattson's the regular style gun in my opinion sprayed much better.. the shop I used to work at had one and I liked if for base.. I like it enough to buy the gravity fed ones. the gun came with two tip sets which was cool cause you just unscrewed a knob and twisted it and it came off to put the other head unit on... But I didn't like that style nearly as much, it was harder to clean, the check valves kept going bad which caused it to not spray correctly, if you somehow kinked a air line and pulled the trigger it would shoot a stream of paint... never had it happen on a job or anything,, I just remember joking that i could use it as a squirt gun to shoot paint all over the boss..lol... but most importantly I didn't like the way it sprayed so It was definetely not worth all the other hassles that came with it.. but on a lighter note, I sold the set on ebay for like $250.00 so if you can buy both of them for let's say $200.00 go for it, and then get rid of them on ebay..lol..
chadsbodyshop49119 11-06-2005 09:13 PM
also thought i'd point out the one in the pic, towards the beginning of the thread is the one that I had and sold
myfamiliacc 11-07-2005 04:21 AM
Thanks for the info... :thumbup:
I know I would be getting them for cheap, but it isn't much of a bargain if they are just going to sit on the shelf.........but you are right, there is always Ebay :D
