max 400 SB overbore? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2002, 02:14 PM
New Member
Post max 400 SB overbore?
What is the max overbore on a 400 SB that is safe to reduce cracking overheating etc??
Old 10-03-2002, 04:19 PM
NAIRB's Avatar
Post
I don't like to bore a 400 much over .030, if it sonic checks at .145 or more on the thrust side of the cylinder, I'll use it for a competition engine, if it's less, I'll use it for a street engine. If you take it to 4.155", you can get your pistons in .005" increments to freshen up, that's what I do with them. I'll start at 4.155 then go 4.160 and so on until it's in the scrap heap out back.
If you use a Bow-Tie block you can go much bigger with your bore, but the stockers are already stretched to their limit at .030
Old 10-03-2002, 04:30 PM
New Member
Post
I am looking at a 400 block that is borded .030 over and they say it has taper that would need to be honed. Sounds unsafe? I dont knwo the casting number yet, but will know by tomorrow I hope
Old 10-03-2002, 04:40 PM
NAIRB's Avatar
Post
It's hard to say if it's unsafe. If it's a bunch of taper, then you'll have to hone it to probably 4.165 to straighten it up, so that's .040 and that's about all I would, so buy it cheap!!! You just don't have anymore room to do much with it. Maybe shop for a different block.
Old 10-04-2002, 02:34 AM
New Member
Post
The block is going for $100.
Old 10-04-2002, 02:05 PM
New Member
Post
So .040 is OK?
Old 10-04-2002, 03:39 PM
NAIRB's Avatar
Post
I think you could get by with .040 depending upon what you want to do with it. If it's a racing type deal, sonic check it, and remember you'll have to probably go with another block if you have to freshen it up sometime or have some problem.
If you go .040 have it honed rather than trying to bore out .010, this will help eliminate spots that won't clean up by improperly centering the boring bar. Use a CK-10 or equivalent machine and use a torque plate. If there are small "eyebrows" where it won't quite clean up after honing, you can run it anyway without any trouble unless it's terribly worn out.
Old 10-04-2002, 04:17 PM
NAIRB's Avatar
Post
Oh, and by the way, I think a 100 bucks ain't too bad for a 400 block, they are getting quite scarce these days.
