max bore of 396 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2008, 11:16 AM
max bore of 396
hey guys i wanna bore my 396 big block , can anybody advice me what is the max bore this block will accept
i appreciate the help i can get
Old 02-23-2008, 12:46 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Definitely .030 or .040. Most will take 60-over, but any more I would sonic check the bores for core shift.
Old 02-23-2008, 02:00 PM
The first 396 was like 4.094 std bore a couple years later 4.125 was std bore, they make .030 - .040 - .060 over for them, I have punched them to .060 over with no problems.
Old 02-23-2008, 02:56 PM
BOBCRMAN@aol.com's Avatar
Early 4-bolt blocks will go 4.250. I have even run one of these at +.030 over that. But you have to have a good block. Get it sonic checked.
Old 02-24-2008, 05:39 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
G'day bopedersen,
BOBCRMAN is correct, 396 blocks can be bored to 4.250". I have a L34 spec 402 (2 bolt ) out of a 1970 Monte Carlo which was bored out a couple of years ago to 427 with no problems. In fact the motor had already been bored .060" over 4.125" for a size at that time of roughly 412/413.
I did quite a bit of research on the subject before getting it bored out and it appears that it was a common "operation" back in the late 60's before 427's where more readily available. From my research it also appears that the 396 and 427 blocks (passenger car blocks not high deck truck blocks) of that era come off the same castings and the only difference was the factory boring. Ditto for 4 bolt blocks.
Core shift was not too much of a problem in Mk. IV Chev. blocks up to the early 70's. Later it maybe an issue. With your 396 if you are unsure then get it sonic tested as suggested.
A side benefit I found by getting it bored out is that it has all but eliminated overheating problems that I was having with the 402. Before, on hot days and nights stuck in slow stop and go traffic the temp. would regularly get to 240 F. and that was with a 15lb cap !. I was always blowing head gaskets. One summer season I replaced 3 sets of head gaskets. Now it struggles to get to 210F. and I haven't replaced a head gasket in 3 years (touch wood ), a great improvement.
Cheers...........Barry.
454 or big bore 396 (402) heavychevy83 Hotrodders' Lounge 1 02-09-2007 07:42 AM
454 or big bore 396 (402) heavychevy83 Introduce Yourself 4 02-08-2007 10:30 AM
350 Build.. Im sure there are plenty of threads on this... but this is specific!! artillerystevens Engine 10 12-04-2006 09:34 PM
max 350 bore brandon624 Engine 13 08-09-2006 05:31 PM
Max bore Jzarczyn Engine 11 06-24-2004 03:01 PM
