Max cam lift for a 350 chevy stock head? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2012, 08:22 AM
Hi
anyone know what is the maximum cam lift for a stock chevy 350 cylinder head? My 350 is from a camaro 76. I got a roller cam with .539 ex lift with 1.5 rockers. Can I use it with a good set of valve springs?
thank you very much
Old 10-16-2012, 08:47 AM
vinniekq2's Avatar
check the clearance,depends on the pistons? Do you have good stainless valves? what are the spring pressures?whats the duration of the cam,,,,
Old 10-16-2012, 09:07 AM
.528 in
.539 Ex lift
duration @ .050: 230 In, 234 EX
Lobe Seperation is 110,hyd roller cam.
Old 10-16-2012, 09:19 AM
BOBCRMAN@aol.com's Avatar
What casting number??
In general.. Stock production heads do not have enuff spring height/diameter to use that kind of lift.. It can be done with the correct springs/retainers/locks and some valve guide modification. Competition Products offers kits with correct components.
Also stock production heads do not support flow/volume much over about .480 lift. or 6000 rpm.
A lot of responses will give you answers that they are running .500+ lifts on stock heads and they make horsepower. But in real life, these are usually a waste of parts.
Old 10-16-2012, 11:27 AM
Agreed with Bob. Stock springs are "safe" to about .470" lift.
Jim
max lift on stock chevy heads small block colton755 Engine 3 05-09-2011 04:27 PM
Head max lift > Cam Max ??? tmwoodall Engine 4 03-14-2011 08:41 AM
max lift with Stock Big block Chevy valve springs garbely1 Engine 1 08-12-2010 12:41 PM
Will this cam work with stock vortec valve springs? what is the accepted max lift? Warrant Engine 1 11-30-2006 01:56 PM
max cam for stock 72 350 exhaust bullheimer Engine 3 04-14-2003 09:15 AM
