Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - max compression ratio on 89 octane
Old 06-23-2005, 06:08 AM
k-star k-star is offline
Last journal entry: PICTURE TEST
compression
Me personally i would not go over a 9:1 static on an engine you are going to run 89 octane in.... But like the others pointed out there are so many factors that can make or break this combo.
To add to what is allready mentioned.
Make sure you can keep it cool ,,,180 deg max... this will keep detonation down..
Make sure you have the correct heat range plug, and the correct timing curve.
Deburr everything in the combustion chamber,,,,,
The bad thing about running close to the edge is if you get a bad load or 2 bad loads of fuel and your not paying attention to whats going on you will have problems....
Learn to read the plugs, You might not hear the detonation.....
keith
