I recently help a friend who had a simular problem with the batt lasting 24 hrs after a chg...... It turned out to the the factory amps killing the batt, we replaced the amps and the problem went away. Might try unplugging the radio harness and put that fuse back in, see if you still get the draw, if you have amps....... try the same, that way you would know what was draining it.
