I recently help a friend who had a simular problem with the batt lasting 24 hrs after a chg...... It turned out to the the factory amps killing the batt, we replaced the amps and the problem went away. Might try unplugging the radio harness and put that fuse back in, see if you still get the draw, if you have amps....... try the same, that way you would know what was draining it.
I recently checked the current draw on my truck, which has a Pioneer radio/CD and no other accessories, and the current draw was about 15ma with the ignition off. My analog multimeter is very old, but I think its still fairly accurate.
Bruce |
parasitic current draw
I have read where 50 ma parasitic current draw is on the high end. Some examples of accessories with their current draw: Voltage regulator 1 - 2 ma, digital clock 3 - 5 ma, quartz clock 7 ma, ECM 7 - 8 ma, radio & clock 7 ma. and there are other relays and sensors that add more parasitic draw.
After a power door lock relay shorted out, the old Autolite battery was completely discharged on my '91 S10 Blazer within 24 hours. I installed a new ACDelco battery and started using a Deltron 800 ma Battery Tender and the problem was solved. I attach the battery tender every time I park the car in the garage. Attaching the battery tender every time I park the car in the garage is probably unnecessary if I would drive the vehicle every day or two. The Blazer may sit for two weeks before being driven again so I hook up the battery tender. I have Deltran's optional battery lead attached to the positive and negative battery terminals so it is no trouble to plug in the tender. Be aware that the ECM in the failure mode can have a high parasitic battery drain that cannot be detected in the conventional manner. When the battery is disconnected the ECM solid state circuit will not show a battery drain until the continuity is restored. Cycling the ignition switch from off to run position may cause the electrical drain to reoccur but do not do that with the amp meter installed in series with the cable and negative battery post. Last edited by MouseFink; 08-24-2011 at 05:36 AM. |
That draw should not run down a healthy battery. Also keep in mind that almost every fuse has numerous circuits so just pulling a fuse normally kills seveal things.
Also consider the method used to test the draw. If you have a low impedance meter in series with one of the battery cables you will get a false reading because you have circuits trying to power up and it takes way more power to power them up than it does to keep them alive but your meter doesn't pass enough currant to power them up.. Last edited by willowbilly3; 08-25-2011 at 03:44 AM. |
With the fuse back in, pull the cig lighter out and see if it's warm.
If so, you've found the drain. The cig lighter and radio are normally on the same fuse (that's still powered with the key off), to keep the radio memory alive. You can also unplug the cig lighter to see if the drain's in the radio. Auto mfgs try to keep the key-off drain around 7-15 ma, to allow a battery to start the vehicle after 30 days. This is good for long-term parking in airports and such... |
| Another current draw problem when off. | al37ford | Electrical | 7 | 07-03-2011 07:55 PM |
| Current draw...engine off | awbazar | Electrical | 3 | 02-08-2010 12:07 PM |
| Question on LS1 starter current draw | grobb284 | Electrical | 1 | 07-16-2009 10:23 AM |
| Current draw-how much is too much? | al37ford | Electrical | 5 | 08-02-2005 03:17 PM |
| What is the normal current draw? | Bryan Munday | Electrical | 3 | 01-27-2004 12:47 AM |
