max lift with Stock Big block Chevy valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2010, 12:06 PM
I would be interested in any ones experience with how much lift a Stock Big Block Chevy valve springs will handle - I want to run a hydraulic (non roller) with .525 intake and .525 exhaust lift and I am wondering if my stock springs will take it
Joe
Old 08-12-2010, 12:41 PM
ericnova72's Avatar
More for Less Racer
Depends on the year of the head what will fit, but why bother?? Why would you want to hamstring your new performance cam with worn out old soggy valvesprings that will likely go into valve float at only 4000 rpm?? They were only marginally strong enough for the stock cam.
You can get decent springs from www.competitionproducts.com Part # 98611 would fit the bill nicely $56
Make sure your heads don't have exhaust valve rotators, it will require a spring seat shim set if they do
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
how much lift on stock valve springs 1badz Engine 1 04-09-2010 05:14 AM
Big block chevy into a 91 S-10?? 12second6 General Rodding Tech 11 04-28-2009 06:43 PM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 11:28 AM
valve springs derek32303 Engine 2 01-16-2006 10:03 PM
