Max spring pressure for "unknown" hydraulic lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2013, 09:36 PM
Hello,
Background
Bought a el camino with a 383 stroker; all unknown parts / engine builder.
Didn't run at first (rich, soaked plugs); traded in the Holly 750 double pump (leaking everywhere) and the dominator intake and for a eddlebrock 750 + peformer.
Msd 6al+new dizzy.
Adjusted springs / metering rods; car RAN GREAT! Cam sounds fairly stout; idles at 1200rpm with 0 vacuum for brakes at idle. That said; the car is a complete dog; feels like a 305... ie: Barely break the tires loose on sand.
lifters where hydralic tappet; nothing special.
Current issue:
Old heads were cart iron smog 76cc junkers.
Had a set of brodix Dirt SPEC in garage; fully assembled for a dirt mod; threw on the car one afternoon.
Adjusted the crank to TDC; Exh 1, 3, 4, and 8 / Int 1, 2, 5, and 7.
Rotated the crank 360; and all the hydraulic lifters on the exhaust valves popped.
Spring pressures are at 240 lb Closed, 550 lb Open; would this be enough to pop a cheapo unknown lifter (or even worse; wipe a cam lobe)?
Or do you think valve hit the piston and I need to tear the heads off?
Should i buy a good roller cam and lifters?
note: Pistons where dished with valve reliefs; looked just like stock mustang pistons.
Old 05-20-2013, 09:43 PM
BOBCRMAN@aol.com's Avatar
MAX seat pressure on a flat tappet hydraulic street/strip cam is 145. Closer to 120 is better.. 240 is roller stuff. Will wipe a flat tappet lobe in a heartbeat..
Old 05-20-2013, 09:50 PM
ack
Looks like I am buying a cam then
Old 05-20-2013, 10:57 PM
vinniekq2's Avatar
make the cam a nice little roller
Old 05-20-2013, 11:24 PM
o
Yep; thinking something on the mild'ish for a solid roller cam.
Hoping to avoid clearance problems by keeping lift under .600 and duration something reasonable (having some vac at idle is a added bonus).
ie:
Lunati#638-40120730LK
Voodoo Solid Roller Camshaft and Lifter Kit
Chevy Small Block
Lift: .555''/.566''
Duration: 261 Deg /267 Deg
LSA: 110 Deg
RPM Range: 2500-6500
Not knowing the cam was bothering me anyways; gives me a good excuse to change out.
Old 05-20-2013, 11:38 PM
vinniekq2's Avatar
check this out
111313-08 NA 279 279 247 247 .585 .585 108 104 .022 .022 1,2,5
3000-7400 Fair idle, Hot Street/Strip. Good mid-range power. 10.0:1 CR, 3400+ stall
Old 05-20-2013, 11:47 PM
Banned
Brand:COMP Cams
Manufacturer's Part Number:K12-443-8
Part Type:Camshaft and Lifter Kits
Product Line:COMP Cams Xtreme Energy Retrofit Cam and Lifter Kits
Summit Racing Part Number:CCA-K12-443-8
UPC:036584036760
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,800-6,100
Intake Duration at 050 inch Lift:242
Exhaust Duration at 050 inch Lift:248
Duration at 050 inch Lift:242 int./248 exh.
Advertised Intake Duration:294
Advertised Exhaust Duration:300
Advertised Duration:294 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.562 in.
Valve Lift with Factory Rocker Arm Ratio:0.540 int./0.562 exh.
Lobe Separation (degrees):110
Grind Number:CS XR294HR-10
Coil spring "extenders", "spacers", etc. connoisseur Suspension - Brakes - Steering 20 01-20-2011 09:40 PM
No oil pressure=noisy hydraulic lifters? scrot Engine 1 03-28-2010 06:19 PM
How much open spring pressure will 3/8" studs handle? hotrodf1 Engine 4 10-15-2007 11:27 AM
Valve Spring Pressure? .509" Lift/310Deg. AmericanPackMule Engine 0 07-28-2004 11:50 PM
any ideas on "cost effective" springs and lifters? 357ford Engine 3 01-12-2004 08:04 PM
