Hotrodders Bulletin Board
#1
Max torque of engine at what rpm?
Hello,
I am trying to figure out which stall converter to buy for my engine so I launch at the max torque. Sbc 406 11.7:1 Compression 2.08 1.6 valves victor Jr manifold 1050 dominator carburetor comp cams roller camshaft 260/264 @.050 106 lobe seperation .660/.630 lift 1 7/8 headers th400 with transbrake and 4.56 gears in a 1972 El Camino!!! thanks Trent |
#2
uneducated guess
3600 rpm
#3
Which roller camshaft model do you have? Usually comp cams will display an operating range for a specific cam and many will have a stall recommendation as well. Most of the time they will give an operating range based on a benchmark 350. Since you have a 406, simply multiply the operating range/stall recommendation by 7/8 to get the number for the larger 406. Usually you want a stall that equals the low RPM number of the camshaft's operating range. If you go too low you will get a softer launch, if you go too high you will get too much slippage at high RPM costing you power. If in doubt, call Comp Cams and speak with a rep.
