Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Max valve lift (chevy)
Old 06-22-2002, 10:37 PM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Post
You should always put valve springs that match the cam on the heads.And change valve seals wile your there. I don't think .467 lift would give you a problem otherwise.Check piston/valve clearance & coil bind.
[ June 23, 2002: Message edited by: 78 monte ]</p>
