maxima 04 burning out ignition coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2012, 06:02 PM
goodday my name is darling and i own a 2004 nissan maxima. my car keeps burning out the ignition coil. I replace the ground cable and i throw new ground for all the coil and i put a new ground on the engine. I changed the 3 catalytic converter. and the engine was getting hot so i took out the termestat and i put the fan derectly so its on all the time. my next option im going to change the crankshaft position sensor or if u got an idea plzzz write back asap.
Old 07-28-2012, 07:25 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
scan tool
The car has 6 ignition coils. One for each spark plug. The coils are controlled by the ECM (computer). The crankshaft position sensor is one of many inputs that the ECM uses to control the coils.
My point is that the trial and error method of trouble locating does not work.
A scan tool and a (trusted) person able to interrput the readings is the way to go. Can you say --- Dealer
It is possible that there is voltage problem that is stressing the coils.
Is this car a tuner?
How does the car run and drive?
vicrod
Old 08-02-2012, 09:20 AM
i fix the problem all this time it was the ignition condenser thankxx
Ignition coil RichardT Electrical 1 01-16-2012 01:01 PM
Burning through ignition coils Steven Pisonero Electrical 66 08-17-2011 07:47 AM
burning up ignition modules, how many volts to coil? munster217 Electrical 9 05-16-2011 04:08 AM
ignition coil smokin63 Engine 1 02-22-2008 07:36 AM
DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder Costa Rica Electrical 0 06-30-2005 02:13 PM
