Maximum angle of drag link to center link? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2013, 01:23 PM
Mutt's37Buick's Avatar
Hoping someone with steering experience can help me out.
I'm designing a drag link and center link for my project.
This is a rear steer set up (steer box behind the front spindles).
My plan is to have a center link that swings on two idler arms like an Astro Van that is pushed by a drag link.
Currently the steer box is 5.4 inches rearward of the center link with an angle between a drag link and the center link of about 13.5 degrees. (See attached)
Is there a maximum angle that is acceptable between a drag link and center link.
Thanks
Name:	Assy, Chassis, v0.20 Scout 2 stand rotation bottom.jpg
Old 05-22-2013, 07:13 AM
Wiki Edits: 27
steering linkage
You need to check how much angle you can move the linkage before the ball and socket binds, you might have to drill the hole at an angle and taper reamed to fit when fabbing new parts or heat and bend. You need to have the ball and socket centered at straight ahead and not bind when turned or use the bind at full left or right as steering turn stops. I have had the side mounted drag link on a t bucket want to rotate when turning the steering wheel. The drag link was bent for tire clearance to turn and the pivot point center lines were skewed in different directions.
Old 05-22-2013, 07:25 AM
Wiki Edits: 27
over center lock up
I have a 1922 model T speedster, dropped front axle, reversed eye spring, steering column lowered, . I have to be carefull when making a new drag link that the linkage won't go over center . if done wrong you can turn and have the wheels pull all the way one direction and you cannot get them to come back straight ahead by turning the steering wheel.
The Following User Says Thank You to timothale For This Useful Post:
Mutt's37Buick (05-22-2013)
Old 05-22-2013, 08:06 AM
kso's Avatar
kso kso is offline
Looks close enough to me...I'd just tweak (grind) the splines on the pittman arm to rotate it a bit and try to get a 90-degree angle between it and the drag link at "straight-ahead".
Later on when it's actually mocked up, do run the suspension (with no springs installed, just the shocks) through all it's paces and angles, checking that there's some movement left in all the joints at the extremes, etc.
The Following User Says Thank You to kso For This Useful Post:
Center Link search Mutt's37Buick Suspension - Brakes - Steering 2 04-21-2012 09:41 PM
23K on center Link earthworm Suspension - Brakes - Steering 5 01-14-2011 09:19 AM
Drag Link Question (Center Tie Rod) Houman SS '70 Suspension - Brakes - Steering 2 03-26-2005 08:56 PM
center link 79 firebird BadAss_Beaver Suspension - Brakes - Steering 9 10-25-2004 10:53 PM
Center link nigelman Suspension - Brakes - Steering 1 10-23-2004 09:14 PM
