Maximum bore size of a chevy 350 block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2007, 04:45 PM
Last journal entry: metal finish
I basically want to destroke my early 350. Getting the cubic inch and stroke that i would like i would need to run a bore of 4.125.. is this do-able? thanks
Old 11-28-2007, 06:14 PM
CNC Blocks Northeast
No Can Do
Old 11-28-2007, 06:37 PM
King of my Man-cave.
You can do that with a 400 block, main bearing spacers, and a 350 crank.
Do that with a 350 block and you will have a Stanley Steamer.
tom
Old 11-28-2007, 07:39 PM
A 283 crank would make a high reving screamer in a 400 block does anyone know if the OHC corvette heads zr-1? will fit and work on the earlier blocks as this would be a truly awesome setup.
Shane
Old 11-28-2007, 08:03 PM
Wiki Edits: 31
283 crank wont fit a 400 block. small journal crank, large journal crank
Old 11-28-2007, 08:14 PM
bering spacers.
Shane
Old 11-29-2007, 02:28 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You can get bearing spacers to run medium journal cranks in large journal blocks (i.e. 350 cranks in 400 blocks) 350s have 2.45" mains, 283s have 2.30" mains. I don't know if you can get small journal to large journal spacers or not. So, unless you can find small to large journal spacers, you won't be able to run a 283 crank in a 400 block.
Old 11-29-2007, 06:36 PM
BOBCRMAN@aol.com's Avatar
Childs and Albert used to list small journal bearing spacers $$$$$
Largest you can bore a 350 block is .080. And that doesn't always work..
Old 11-29-2007, 08:20 PM
327 lg journal will work, the same dimentions as the old nascar engines.
Old 11-29-2007, 08:34 PM
I have heard of it being done before ..... Someone on here had one IIRC couldnt youjust weld the crank and have it turned down then use normal bearings?
Shane
Old 11-29-2007, 08:36 PM
But a 327 crank is a l3.25 stroke. What about an l99 (bably lt1) 3 inch crank and a main seal adaptor
Shane
chevy block question joesnova2 Engine 15 05-01-2007 09:20 PM
350 Chevy block casting question flyin99 Engine 7 08-14-2006 08:55 PM
big block chevy "tall" lifter bore BBCMudbogger Engine 3 12-07-2005 08:19 AM
Maximum bore on Chevy Tall-deck? drlindz Engine 9 12-05-2003 05:05 AM
Small Block Chevy 350 firebirdzig Engine 2 06-29-2003 04:30 PM
