maximum torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2010, 03:41 AM
maximum torque
Own a 1987 Chevy 5.7 fuel injection engine. I used propane to attempt to detect a leak. I got a small verification of the engine's rise in idle after going completly around the manifold. I guess about midway on the passager's side a spam of one inch of area the engine rose in idle. I got the bolts torqued down to 43 foot pound. Can I take my torque up to 48ft lb? I am not sure if the manifold is cast or aluminum. If you got both specification that would help out a great deal. For the record I have taken the TB off of the manifold and replaced the gasket under it and gave it a good cleaning. The manifold is stock. I've post previous threads on this subject about 3or 4days ago.
Tommy
Old 08-14-2010, 05:59 AM
ericnova72's Avatar
More for Less Racer
Usually once you have a leak between the head and the manifold, no amount of retorqueing will fix it, especially if the gasket is more than a few years old. It is time to replace the gasket. Going higher on the torque runs the risk of pulling the threads out of the heads, you are already over the recommended torque of 25-30 ft.lbs.
Old 08-14-2010, 01:53 PM
bigdog7373's Avatar
Of course it's fast
If you need to torque the intake bolt to 43 pounds and still have a vacuum leak then your gasket it shot. Do it right and replace the gasket, it's really not to difficult. Just make sure you drain the coolant completely.
Need a New Torque Wrench DTL504 Engine 33 10-25-2007 06:06 PM
torque converter banging??? Flywheel or tranny?? boneyard Buick Engine 5 09-04-2006 03:07 AM
increasing low end torque fast68 Engine 3 07-31-2006 04:27 PM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
Torque & HP for 355 SB Chevy bigjoedo Engine 7 04-17-2002 10:11 AM
