Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Maximum valve lift for 2.02 / 1.6 valves in 3.776" bore
Old 02-29-2012, 01:30 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Bolt the bare block onto an engine stand. Put a set of valves into the head with checking springs. Bolt a head onto the block and look up the bore. Push the valves open with your fingers. You'll be able to figure this out pretty quickly.
