Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Maximum valve lift for 2.02 / 1.6 valves in 3.776" bore
Old 03-01-2012, 03:16 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you are going to attempt the 2.02/1.60 valves you NEED TO TURN THE ENGINE OVER BY HAND and CHECK PISTON TO VALVE CLEARANCE before running it. I I'm curious if they will even be able open all the way without hitting the cylinder bores...
Either way, it's probably not a good idea to use valves that big.
