Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Maximum valve lift for 2.02 / 1.6 valves in 3.776" bore
Old 03-01-2012, 06:00 PM
engineczar's Avatar
engineczar engineczar is offline
The other problem you're going to run into if you use the Bowties is that the chamber is bigger than the bore by quite a bit. The top of the deck is going to encroach into the chamber leaving a healthy step.
BSE Racing Engines
